I just installed a circupool swcg (love it!) and now I've ordered solar heater panels to install on a ground level mount. I have read that the swcg should be the last item before the return. It would be far easier to install the solar panels after the swcg, but I am concerned about having problems with chlorine gas buildup in the solar panels when the pump and swcg are turned off.
edit: I have decided to install a 3-port diverter valve before the SWCG so that the water going into the solar panels bypasses the SWCG. I think there should still be enough flow for the SWCG to operate, and enough flow for the panels.
