Hello!
First winter with a pool...
I live in the Atlanta Georgia area and our winter climate is fairly mild, although we will have a few weeks of sub freezing temps. Due to our temperate climate and the fact that I like to look at the pool, I have chosen not to cover or "close" the pool. The pool does NOT have a heat source, so swimming in the off season is not an option.
I just discovered the other night during a frost that the pool pump has a "freeze protection" mode! Question 1: What is the ideal setting for this mode? It is currently set to activate at 36 degrees and run the pump at 2500 RPM.
I have been considering a the solar disks something like this: This is not my pool.. this is a screenshot from amazon
To help keep the water from freezing and to ultimately help protect the pool equipment when the weather drops to sub freezing temps for multiple days. Has anyone used these before for this reason? Again my goal is not to make the pool warm enough to swim, but rather for preventative freezing measures.
Will increasing the water temp with these things have any effect on freeze prevention/protection?
Thanks
Thanks
