Thank you. Anyone in FL know when the water is relatively warm enough to swim again this spring? I’ve only had my pool since last June and want to use it in March if possible.
I would say that is a bit of a loaded question... What direction does your pool face? If it's on the south side of your house, it will heat up a bit faster than anywhere else.
My experience with 2 pools (west of Orlando), let me preface with comfort being around 85 degrees for me... My first house had a 22,000 Gal pool, 8' deep on the west side of the house, no screen. It would get to temp in early June really. Some years a little sooner. Once the heat of the summer kicked it, it stayed relatively consistent. I think the depth was an issue on that pool.
My last pool was on the north side of the house, with a screen enclosure, around 16,000 gal. Again, probably June before I really felt like I didn't need the heater. It also seemed to fluctuate more with the weather. Several rainy days in a row would drop the temp pretty quick. Some of this was shade due to the screen and some related to being on the north side of the house. A heat wave in April/May would get this one up to temp though
Our new build will be on the south side, so I feel better about how things are going to work out.
Now, my opinion on your options...
Solar cover - these work. I had one on my first pool and it definitely extended the season. As Kim mentioned though, it was a PITA to put on, take off, monitor water balance, etc. Plus, you're hiding your pool. But I admit, it absolutely works.
Solar Panels - will help if you have the right roof space/direction. For me, this is the most convenient option. You don't have to make a decision about turning on a heater and spending money to heat, you don't have to plan in advance, etc. They will extend your season, but if we get a warm day in December and you want to use the pool, it's not going to do it for you then. My inlaws in SW florida have solar panels + cover and they can keep their pool in the low 90s easily. I have heard complaints though about reduced roof lifespan with solar panels, so that is something to think about... Not sure if you're a local, but around here, most roofs lives are dictated by when a hurricane comes through. I would say that very few roofs really make it to their full useful life and just get replaced due to age.
Heat Pump - This is what I will have due to spa. Works great if you plan in advance and don't want to swim if it's under say 70 degrees outside (plan way in advance for this). In our last house, we would decide on Thursday/Friday if we wanted to use the pool on the weekend and turn it on depending on the outside temp. Lower temp, turn on Thursday night, higher temp, Friday would be fine. My biggest complaint was that on a Tuesday, if I randomly wanted to use the pool and didn't plan for it, it was a no-go.
In the perfect world, if money was no issue, I would have solar panels and heat pump at a minimum... solar cover + someone to deal with the hassle of it is a huge bonus, but I have tried it before and it's a waste of money for me because I don't want to deal with the hassle.
