I've got 10kW of grid tied solar electric powering the house. Roughly 30,000 BTUs of solar thermal vacuum tube collectors pre-heating my domestic hot water. I'm now looking to add heat to my pool and of course looking to do it via solar but came to a dead stop in my assumptions.
I was assuming to duplicate my existing system, utilize solar thermal vacuum tube collectors, run it through a heat exchanger and heat the pool that way. But looking through the boards here, many people are using solar panels driven directly off their pool pumps.
From an initial overhead, it does seem to be cheaper. A titanium heat exchanger alone is $400. Another $200 for a water pump, and then the cost of the panels themselves are more expensive ($800/ea). But the setup would be much more robust, resistant to bursting, more resistant to weather, and potentially alleviates stress on the pool pump itself.
That's about all I came up with, are there any other reasons? It's hard to find info on btu/sq ft on the pool specific solar panels, but that's another area that I can think of where space may be a concern.
Specific to me and what I'm looking to do:
We've been pretty happy with temps for our use during July and August. It takes about a month and a half to get up to temp on it's own, so we're looking to help bring it up to temp a bit faster - target is about one to two weeks. The intention is to buy commercial parts, but do a DIY install this year.
36,000 gallons
Pool is open 4-6 months
Avg. Startup Air Temp: ~65F High / 40F Low
Avg. Startup Water Temp: ~50F
Avg. Peak Air Temp: ~88F High / 65 Low
Avg. Peak Water Temp: ~80F
Avg. Closure Air Temp: ~70F High / 55F Low
Avg. Closure Water Temp: ~68F
Desired water temp: 80F
36,000 gallons
