I have a new concrete in ground pool and attached spa that has an overflow into the pool. I have a pentair intellicenter, a pentair vsf pump, raypak gas heater and solar system on the roof. there are actuator valves to switch between pool and spa with a manual spa makeup valve to the spa can be kept full and over flowing into the pool during pool operation. I also have an actuator on the solar valve and it all works as expected and I've got the programming working ok. But I have a couple of questions and looking for advice:
1. The options for heat are gas heater, solar only or solar preferred. I'd like to have both solar and gas heater working at the same time if there is enough heat in the roof but I want it to heat quicker. Can't see how to do this.
2. I'd like to tie the pump GPM to the solar valve. I.e., Keep GPM at one level when solar is off but increase GPM when the solar valve opens. Currently I can only see how to tie pump GPM to a time based schedule.
