OK folks I am beyond frustrated and about to call a pool guy and get on with my life.....I have an algae problem that wont go away.. I have been dealing with this problem since March..First off I got a new liner installed and filled up my pool its been crazy hott here in Charlotte above 90's most day since June and still going..My pool is losing water about an inch a day.. I thought is was evaporation but soon decided (bucket test) that is was a leak...Leak pro is on vacation for 2 weeks.. really 2 weeks in the middle of summer but that's another story..So i have been topping off for an hour every other day..Finally got some advise from a pool cleaner friend of a friend and he suggested shocking the pool.. So i put in 5 pounds HYPO and after running the pump 24/7 a day and a half later is was perfect...beautiful clear water.... Then last week went on vacation for 4 days and had to shut of the pump for fear of burning out my motor...pool leak guy still on vacation...dude really???....came home to pool level under the skimmer and more algae...cloudy water cant see the bottom of the deep end so again filled up for 3 hours to acceptable level and then shocked again this time with only 3 bags figuring it wouldn't need as much and am fearful of harming my liner.. 2 days later still cant see any difference and I still have algae. I assume I didn't use enough shock this 2nd time so I add a bag last night and still no difference..I tested again this morning only had time to do my PH and its pinkish red and above 7.8....I assume I need to bring that level down?
So my questions are:
Is shocking more than once a season harming my pool...
If my PH is high will it take longer or is it a waste of time to shock if they are so high...
should I shock again using the 5 bags recommended and try again but wont this be bad for my pool?
I will update numbers this evening....
Thanks for the advice in advance
