- Dec 5, 2020
- 12
- Plaster
- Pentair Intellichlor IC-20
Hi. I have swg gunite pool that is just over 1 year old. Filled with city water and no metal (that I know of). Had a small pea size rust stain in my hot tub that I rubbed on it and went away a couple weeks ago. It came back and I put 3-4 vitamins in a sock and crushed them and let it sit on the spot for about 40 minutes. when I came back to a large brown stain about the size of a fist was where the sock was. I can’t clean it with a brush, or rubber ”stain eraser” Does this sound like copper or something else? No copper pipes, no exposed metal near my pool.
I started a slam yesterday as I have been losing fc was dropping more than normal. But really clear water so really just making sure with the slam and then was going to raise the cya which is low and probably the cause of the chlorine depletion. My oclt was between 1-1.5.
fc:13
cya: 30
ph: 7.2
any help is appreciated
fc:13
cya: 30
ph: 7.2
