My fiberglass pool is about 15 months old. I found water is leaking from pool and tracked it to a couple small cracks (maybe 3/4" and thin, at where one of my LED lights is mounted to the pool. I suspect some kids (guests) we had over used the light as a step to help climb out of the deep end. I will have if properly fixed soon - can drain below light level and fix - ideally in a few weeks once swimming season is over.
What I would like to do now is patch in some temporary way which will not damage the fiberglass or be difficult to remove, and could be done with water still in the pool. I would need to drain about 1 ft to get to lights for more permanent and proper fix. This light is in the 8' deep part of pool. I don't want to keep filling without a fix and erode soil around pool, but dont't think that would happen easily, and no evidence of it yet. Leak just "appeared" last week. If no good way to patch now, will just drain below lights and use only drains for filtering and get someone here ASAP.
Update 9-5-17:
Just decided to let it drain below leak and have it properly fixed. Had pool installer come by today and they will talk with pool mfgr and get back to me. "May" be a ground settling issue - putting pressure on the light conduit - transferring it to the pool side.
Gary
Update 9-5-17:
Gary
