I processed my first SLAM and would like to know if someone could explain what might have happened that would have caused me to use 33 gallons of liquid chlorine.
Situation:
Water Quality Prior to testing
Prior to SLAM I Purchased 16 gallons of LC (10%) from local pool supply, which they asked me three times if I was sure that was the correct amount! As instructed, I vacuumed pool to remove heavy debris.
So I began the SLAM in the morning with a commitment to maintain a FC shock level of 15 but I didn’t imagine I would go through 31 gallons. Based on my pool volume, 1 gal LC(10%) will generate 2 ppm so I planned to start with 8 gallons of LC.
Timeline:
As of today, pool has turned from green to grey and continue to show improvement. Recent readings are:
Any thoughts on what I did right or wrong? Any concern of side-effects...other than damaging the liner? I'm hoping that I had a bad case of algae that I may finally rid this pool of!
Situation:
- Pool – 36,000 gallons
- Located in wooded area and algae is a chronic issue we deal with
- Temp – 55 and no sun
- All test performed using Taylor Test Kit (K-2006).
- Pump flow is 49.5 GPM (Metered)/ 12 hours = 36,000 gallons.
- Sand Filter.
- Pump did not turn off except for backwashing.
- All Chlorine was applied evenly by circling the pool, one arm length away.
- CYA – 30 (also tested by pool supply stating 38)
- PH – 7.4
- CH – 90
Timeline:
- Add 8 gal of LC (10%), test after 30 mins FC = 8.2
- Add 4 gal (12 total) of LC (10%), test after 30 mins FC = 8.8
- Add 5 gal (17) of LC (10%), test after 30 mins FC = 8.8
- Ran to local grocery store for 8 gallons of bleach (8.25%)
- Tested 60 mins since last test, FC = 9.6.
- Sent wife to different pool supply store for 16 more gallons of LC (10%).
- Add 4 gal (21) of LC (8.25%), test after 30 mins FC = 26 (yikes). Conducted 2 additional test from different locations with similar results.
- Started to brush for the first time and tested after 30 mins. FC = 9.6
- Add 4 gal (25) of LC (8.25%), continued to brush and tested after 30 mins. FC = 12.5
- Add 3 gal (28) of LC (10%), brushed then tested after 30 min, FC = 16.5
- Add 2 gal (30) of LC (10%), brushed then tested after 30 mins, FC = 19.0
- Tested 30 mins late, FC = 18.5
- Tested 60 mins later, FC = 18.0
- Tested 60 mins later, FC = 17.0
- Added 1 gal (31) of LC (10%), tested 30 mins later 18.5
- Tested 120 mins later, FC = 15.
- Ran out of FAS-DPD (0871) and no store are open.
- Added 2 gal (33) of LC 10% to carry me through the night. Only means of testing FC are test strips which indicate FC above 10.
- CYA-30
- PH-7.2
- FC-Still above 10 (using test strips)
- TA-90
