Please back off on the caps. We are all volunteers and doing the best we can. The caps make it seem like you are yelling.
Unless you plan on changing something, put your current results in both the "now" and "goal" areas. Right now, for you, that would be everything except FC.
You told us your CYA was 30, so use that value. If you are unsure, please retest it. It will make a difference on how much FC you need to add. For a CYA level of 30, your SLAM FC goal is 12. For a CYA level of 50, it would be 20.
Make sure you go to the bottom of the page to the yellow portion labeled Suggested Goal Levels. Choose troublefreepool, vinyl, and bleach. Your suggested levels will appear in each individual row/box. See also: Pool School - Recommended Levels
