Hello
I have a 15000 gal saltwater pool. It had been covered, not in use for 3 years. Removed the leaves, raised cya to upper 20s, started shocking, and added algecide. Flocked twice, didnt make much difference. This was before I found pool school, pool math app. Started a slam since March 30th. Cya in the 20s says my target is 10 ppm chlorine. I have maintained this pretty well with the exception of all the rain we have been getting. Lowest fc was 6 which I brought back up right away. I have been using 65% cal hypo granules, brushing, and vacuuming almost daily. Water is still cloudy, dark but I can see about 3 ft down. Went to leslies today, just to see how my chemistry looked. Will post results below. I am using the taylor fas dpd test kit for chlorine tests. Anything is should do differently? Seems like clarity progress has stopped.
Fc 6.69 brought up to 11.5 now
Tc 7.87
Ph 7.87
Ta 102
Ch 126
Cya 24
Iron 0
Copper .3
Pho 196
Salt 2616
Tc 7.87
Ph 7.87
Ta 102
Ch 126
Cya 24
Iron 0
Copper .3
Pho 196
Salt 2616
