Hi all,
First of all, thank you for all your resourceful info and generous posts!
I got back from my summer break to a green pool. A rabbit got caught in the skimmer preventing the flow needed for my SWG to work.
I followed the SLAM process and started by measuring the CYA (55) and getting my pH to 7.2
Then I re-calculated my pool volume which led me to the some inconsistencies depending which calculator I used:
Leslie's pool calculator said 25K, ChatGPT gave me 27K, some other website gave me 32K and TFP gave me 29K so for the sake of trust in TFP I marked it as 29K.
I have a 40ft by 18ft oval pool with curved bottom at 4ft and 8ft depths so an average of 6ft.
The SLAM calculation gave me 22 so I added enough 10% liquid chlorine to keep at SLAM level.
It's been over a week. The green was gone in the first 2 days and now I'm dealing with the cloudy water.
I've been good at testing and maintaining, sometimes 5 times per day and my CC is 0.5 and the overnight loss is under 1ppm.
I have already poured 38 Gallons and have 10 boxes waiting in the garage. BTW Home Depot does nice bulk pricing if you buy more than 4 boxes (at $6 per Gallon / $12 per box).
Which was surprising after reading that I should buy double my initial SLAM... it's been 4 or 5 times that! I know I'm in the California desert and it's VERY hot these days (that's why I need this pool!!) but it might be worth noting that it could be as much as 5+ times that
I do think I have bad water circulation due to the design of the pool, which was done in the 50's and re-routed using PVC pipes for the SWG.
The skimmer and the return are on the same side in the middle of the pool, so there is not much circulation on the shallow end. You can see less jet turbulence on the left below.
I think this is why it might be going slower. I was planning on leaving this weekend but I'm afraid I might still be SLAMming.
I do have a bottle of Leslie's Ultra Bright Advanced Enhancer that I used before with stubborn water and it worked and was wondering if it might help clump those white particles together.
I also have a Phunky Phostate Remover but I read that is never recommended, but I have it so it would just sit on the shelf anyways...
At this point everything is dead in the pool, all the algae, larvae, backswimmers and water boatmen, so I'm just dealing with bleached out dead algae.
I brush once a day and use the pool robot to vacuum but I started doing manual suction as well. I'm also now leaving the suction hose on the shallow end to see if that helps with circulation.
I also closed down the skimmer float valve to allow more suction from the main, under the skimmer since most of my problem is below the waterline.
Oh and I clean the filter once a day or every 2 days. I wait to go 10 over the starting pressure as to not waste that much water every time I open it.
Any tips would be greatly appreciated, especially with adding the enhancer, phosphate removers or improving circulation and anything else!
This was two days after but it hasn't changed much since... its going veeeeery slowly. It's hard not to lose faith when it's going so slow
Thanks!
Thanks!
