Mdragger88
Admirable words and goals but that's not how it works.IMHO I don’t want to barely pass, I want to pass with flying colors. Tomorrow’s test may very well pass with a perfect score due to my errors or a ever so slightly more accurate test on the 2nd attempt. But it takes a ton of work to get to that point and just a little work to let it ride for one more day so to me it’s worth it.
I appreciate it but it kinda is how it works. Per the SLAM rules, a FC loss overnight of 1 PPM or less is passing. But is it really 1 PPM, or did I accidentally only use 9.8 ml of test water that sure looked like 10 ml ? Or were a few of the reagent drops slightly bigger and made the test pass? My 1 PPM loss is really a 1.1 and then fails, but is indistinguishable between the two. At a loss of 1/2 FC it can be off by a hair and .6 still passes with plenty of room to spare.Admirable words and goals but that's not how it works.
Well whatever was hanging on your killing it now... WOW, a 1.5 cc is up there and that is actually good in your situation because you know your killing whatever was left.. Great job.... I will say that you will get a FC loss with a rain event because it is diluting your FC amount that you had before but the fact that the CC went up is the key..Well, that was fun while it lasted. I'm super duper chlorinating at the MA level, and got a 2.5 FC loss last night, and a CC of 1.5 this morning.
It stormed a bit last night, and I ended up with another inch of water and a few leaves in the pool, but that shouldn't affect chlorine levels that much, from what I've read in the forums.
And so it goes....
Thanks. Perhaps this "super slam" is the finishing move I need.Well whatever was hanging on your killing it now... WOW, a 1.5 cc is up there and that is actually good in your situation because you know your killing whatever was left.. Great job.... I will say that you will get a FC loss with a rain event because it is diluting your FC amount that you had before but the fact that the CC went up is the key..![]()
