SLAMing new water. SLAM before increasing CYA?
bobhatfield
36
Phoenix, Arizona USA
Pentair Intellichlor IC-40
Had to drain/fill due to very high CYA and mustard algae. Should I SLAM before bringing my CYA up to recommended? It's essentially 0 now. Assuming that will save me some chlorine during the SLAM process?
Yes, you should get your CYA up to a minimum of 30-40PPM. It will probably cost you in LC purchases in the process if you dont because the sunlight will eat up the FC quicker, thus needing to add more LC.
Reactions: bobhatfield
