Test FC after the sun stops shining on the water and again in the morning before it hits it again. In a perfect world, the two readings will be the same, because two things consume FC: Organics (algae) and sunlight. By eliminating sunlight, you can see if you lose any to organics. That's an Overnight Chlorine Loss Test -- Overnight Chlorine Loss TestI tested the FC at 8 ppm around 1:00 PM. Should I test again in the morning or afternoon?
I will shut the pump off and take another photo.
I'd start now. Otherwise, the algae that's in there will have an extra day to grow.I tested the FC this morning and dropped to 3 while the CC held at 0.5 or 1 ish. Time to SLAM? If I do should I start it this evening when the sun goes on the other side of the house?
CC will fluctuate. Even when a pool is pristine and hasn't seen algae in years the CC pops up once in a while. Don't fret about it.It rained all day today. The pool is higher than it should be. I hit it with 9- 121oz (1089 oz) jugs of Clorox around 3 PM.I let it circulate for an hour and I just re tested it. The FC was 25 ppm and the CC was still at 0.5. Should it still be at 0.5? It almost registered that it had "0" CC. Can I not test for CC while the FC is this high?
I added another 121oz of Clorox to see how close that gets me to the desired 28ppm for the shock. I will re test around 6 PM.
64ish.
Back up to 28.The last test last showed a FC 28. This morning the OCLT was 26 and the CC is probably below 0.5.
Should I bump the FC back to 28 or leave it alone?
