So I started SLAMing my pool around 2 weeks ago. Went from very dark swamp green water to blue. All of my numbers look great (except I'm not 100% positive about my ph. I started at 7.2, but have held my FC level at 22-29 due to my CYA being 70-75ish and haven't tested since). My water is still very cloudy. The pool "turned" blue on 7/21. I can't see the vacuum head while vacuuming. If I keep my FC level at SLAM level, can I turn off my pump overnight to let things settle and vacuum in the morning? I've only backwashed when my filter reaches about +7 psi which is when I start to lose good pump suction. Now no matter how much I vacuum the pressure doesn't rise (3 days of vacuuming and I've had a +1.5 psi rise). I've attached a pic of my vacuum in the shallow end. Top of the water seems clear. I've asked this same question on reddit, but a few people basically said go ask tfp, so here I am.
