I’m doing my first slam and need some help. I got lazy with my pool care and 2 days ago saw some algae in the pool. Did a test with FC 0, and CYA seemed super low because I could still see the black dot with the view tube completely full. I assumed my CYA was maybe 20. So I went and bought dry stabilizer Friday. According to pool math I put 2lbs in using the skimmer sock method which should have raised my CYA to 45. I got all the leaves out of the pool Friday and started slam using 45 as CYA to calculate my slam FC level. As of today my water is super clear, I have no more pollen or leaves. It has now been 48 hours since I added the CYA and the sock is now empty. When I retest my CYA is reading like 70ish. Is it possible it just needs more time to distribute within the pool before I can get an accurate reading? Or could I have gotten a falsely low CYA reading before starting slam for some reason? Either way by pool math the 2lbs should have raised my CYA by like 23ppm. Long story short I just want to make sure I get the slam right and raise my FC high enough to be effective. I’m assuming that my FC probably killed everything before the CYA I added could dissolve. Should I just raise my FC now assuming my CYA is 70, then do an OCLT and check CC tomorrow? Thank you!
