after finding this site.... i truly had a trouble free pool for a long time..... but this past year has been a struggle. I repeatedly have slight algae... it shows up one day when i do my normal brushing of the sides. I get a slight green cloud. So I SLAM it...... after several day I pass the Overnight test and i vow to keep the chlorine level just a little higher. Next thing i know.. i have the green cloud again. I test.... my chlorine js at 5 ppm...so its not too low... but algae is back. Soo...maybe I didnt really complete the SLAM correctly. So i SLAM again..... a month later... green cloud again. I test... chlorine is still showing 5... so i wonder if regents are fresh so i order new and SLAM again. Green cloud comes back a short time later.. etc.
So I started a SLAM 5 days ago. Adjusted PH before i started... free CL was at 5 when i started... CYAnat 60. Used pool calculator to find amount of bleach to use to raise to 24... i have had to add lot of bleach during the day ... some because of heavy rain fall! But what is surprising me is the huge drop im seeing overnight!
after 5 days...still a 12 ppm drop? By now Im Usually getting close! What am i missing? Visually pool is clear... i check all the places i can for hidden algae..(behind lights ) my CYA tube black dot is a little faded so i compensated for that.... could i be wrong on my CYA? what am i doing imcorrectly this year... obviously my other SLAMS didn't work because Im wrong somewhere ?
lisa
lisa
