Hello! I am in my 6th day of a SLAM:
CYA 30-35
maintained FC of about 14-15
Kept my pump at 2250rpm 24/7
Two SLAM questions:
1. My pump stopped last night, probably did not run for 5ish hours over night, will that throw things off for me?
2. Three and four nights ago I had an FC drops of about 3-3.5ppm each night; two nights ago FC dropped 2.5ppm and then all of a sudden, last night I had 0 FC drop. Is that possible to go from having a noticeable chlorine demand to having none in 1 day during a SLAM? Or did I screw up my test and/or did the pump being off most of last night skew the results? I tested this morning twice to confirm but only once last night. I did not add chlorine after my test last night. Test last night was 11pm, this morning was at 6:30am.
I'll be moving into the muster algae FC levels for the next 24 hours, should I wait another day and continue the SLAM at the current FC14 level before jumping up to FC22, or is it reasonable that I'm done with the SLAM? Water has always been crystal clear and the CC has been very close to 0 the entire time.
One general question, the Pool Math calculator shows I need " non-SWG Minimum: 3 but a Daily Target: 5 to 7." This means shoot to keep 5-7 in the pool, but it can dip down to 3 accounting for the sun, right? I don't want to make any more assumptions about my pool. isn't 7 a bit high in general![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
CYA 30-35
Two SLAM questions:
