Hey all you pool cat and kittens!
After many battles with my pool I have turned to the internet and I feel grateful to have now found this community as I hope my time here turns me from an ignorant pool-boy to well educated pool-man!
To get everyone up to date I have an in-ground open-air pool. I bought my house a few years ago and knew nothing about pools then and still know very little now.. but I've been digging into the resources here and trying to learn! My first step was buying the K-2006 test kit which was delivered today and here are the following results from my tests:
From what I've read on this site so far, based on my CYA test result, I should drain at least half my pool and fill it with tap water. The thing is... I have no clue how to do that! I have attached a picture of my pump and filter system and I do not believe I have a way to drain water to waste. So any ideas on how to tackle this issue would be appreciated!
On how my CYA levels got so high? I've been battling a gnarly algae problem that just wont go away and in my ignorant wisdom I thought lets put the 7 remaining chlorine pucks I have into the pool at once to try and really shock the system!, which was clearly a mistake. I have scrubbed the floor and walls with my brush and when the pump is running it does a good job to clear up the pool a bit, but as soon as the pump is off overnight the floor goes back to a layer of algae. I ran my pump for a couple of days and cleaned the filter during but it didn't matter, the algae would come right back as soon as the pump was off for a few hours.
Anyways, thanks for coming to my TED Talk. I hope to learn how to defeat my pool monster and keep the pool in good shape going forward and I plan to document my process here as I know I will have questions along the way.
pH: 7.4
FC (1 drop = 0.5 ppm): 34 drops to get to clear = 17 ppm.
CC (Don't know if this really worked): 5 drops of R-0003 did not change color at first. 30 to 45 sec later color changed to a slight purple color and it took 5 drops to get back to clear = 2.5 ppm
TA: 70 ppm
CH (Don't think this one worked at all): I couldn't tell when it went from red to blue. More like red to clear/very slight tint of blue. Between 30 and 40 drops = 300-400 ppm
CYA (Why didn't I just do this one first so I could have saved the reagents from all the other tests?): 100+ ppm. The test kit's first bar is 100 ppm and I didn't even make it halfway to that mark.
