Slack in liner above waterline
Tom322
1
28655
This forum has been a get resource for planning my new above ground pool and I'm hoping y'all can come thru again.
I'm installing a new above ground pool and I'm at the point where I need to cut holes for the return jet and skimmer. I have the water a few inches below the return jet, but I still have slack above the water line where I need to cut the hole for the return jet. The liner is only loose in this 3 ft section and a 3ft section directly across the pool. It is tight without any slack around the rest of the pool.
Am I OK to cut the hole for the return jet and skimmer? If I do does the slack need to be above or below the return jet?
Welcome to TFP.
Sorry, no one appears to have advice for your situation.
