Whether you use dichlor, trichlor, or liquid chlorine, you will of course need to continue adding chlorine each day for sanitation. Just never add those products to the same location at the same time as muriatic acid. Separate by a few minutes with good water circulation. Remember that dichlor and trichlor are stabilized forms of chlorine and increase the CYA level. The FC level must be balanced to the current CYA as noted on the
FC/CYA Levels. The higher the CYA, the more FC required. Liquid chlorine has no such stabilizer increase effects.
