Skimmer Wizard attachment points
Buggs
49
Eagle, ID
My Skimmer Wizard got installed for the fall leaf season.
I wanted some alternative attachment points to relieve me from disconnecting the Skimmer Wizard when servicing the skimmer basket. I thought of fabricating a couple of small ABS plastic hooks and using Plast-Aid to attach them inside the skimmer where they do not interfere with the basket. However, I decided to first install some temporary hooks to ensure I had the right placement. I installed two 3M adhesive hangers (3M 17081-8ES) in the skimmer and attached the Skimmer Wizard.
The positioning could be a bit higher, but the attachment lines currently allow the weir door to float to its normal height.
Although I intended this as a temporary measure, I am impressed that the hooks have stuck in there for several weeks. I don't know how long they'll hang around, but I'm going to leave them there until they fail.
Anyone have other ideas for how to make skimmer anchor points?
Pull the deck access cover for your skimmer. Do you have two screw holes/anchors that the skimmer lid is supposed to secure into?
Yes, it does. It's a Pentair Bermuda skimmer. What'cha thinkin'?
If you get a different bungee cord, the style with the metal attachment hooks, they fit into the screw holes. I attached a similar setup with a bungee cord looped through the middle and the two metal ends attaching into the cover anchor holes.
Reactions: Buggs
