Good evening, all.
I’ve been thru the search function and am not sure I found the answer.
Here’s my problem: After installing a vacuum plate and priming my vacuum hose, once the hose is installed and pump running, the water is going thru the skimmer around the plate. Am I failing to get a proper seal from the vacuum plate?
The plate is the oem part for the skimmer.
Thank you.
Thank you.
