Heya,
Up until two weeks ago I knew nothing of pool maintenance until I decided to clean my parents' pool this year.
For two weeks, I've been solving problem after problem (mainly thanks to this forum) but I'm lost on this one.
First things first: we have a 75m³ inground pool with a 640 Kripsol sand filter.
I've been going crazy trying to find out why there was a bunch of air in my pump strainer basket.
I opened up the pump and there was a piece of rubber stuck in the impeller, blocking half of the entrance.
I removed the debris and thought I solved all the issues and I was the pool God.
Nonetheless, the problems were still present.
One day, I decided to clean out the skimmer to see if there was a difference.
Immediately the pressure went from 0.5 bar to 0.7 bar and most of the air bubbles in the pump strainer basket disappeared.
About an hour or two later, some leaves (not a lot at all) will have collected in the skimmer again and pressure will fall and air will appear in the pump strainer basket again.
If I remove these leaves, pressure will rise again and air disappears again.
What does this indicate? A (partially) blocked skimmer line?
I tried blowing out the line with a garden hose and a rag (they don't sell drain kings in The Netherlands), but to no avail.
Could this also have to do with the issue of the pool bottom being dirty again just 2-3 hours after completely cleaning it?
Other problems include (don't know if they are relevant): very low backwash pressure, pump sometimes not turning on in the morning and shortage in the circuit breaker when turned off, pump losing prime overnight, sometimes when switching modes on the multiway valve the pump will not turn on anymore
Thanks in advance!
Thanks in advance!
