- Jun 12, 2023
- 194
- Plaster
- Hayward Aqua Rite (T-15)
So with vac handle at 3 o’clock (turning off main drain) and skimmed handle at 6 o’clock, I may be having 50/50 to vac and skimmer?The valve handle is exactly opposite the diverter plate in the valve.
So if the handle is at 6 o'clock, there is a 50/50 chance to pull equally from both feed lines.
I used the word "chance" as there are additional factors involved with the plumbing - but it's basically 50/50 to each port.
In my tests if i had main drain turned off (valve labeled vacuum at 3 o’clock) my vacuum doesn’t move at all basically no matter what position I put the skimmer valve handle.
