My pool is 18x36 gunnite, with one skimmer, one sidewall and one main drain on suction side. I recently changed out my old Pentairt WhisperFlo single speed pump motor for the Neptune variable speed. Works well, pressure at returns is strong. As you can see in photos attached, swirling action in skimmer also looks good/active.
But the skimmer does not appear to skim. As you can see in the second photo, leaves and other things flow right by the mouth of the skimmer but do not go in. The weir door doesn't seem to fold down all the way to create the waterfall effect. Is it a water level issue? Waterline is only halfway up the skimmer as you can see in photo/video. Other? Appreciated,
