- Jul 18, 2017
- 244
- Plaster
- CircuPool RJ-30 Plus
Our replaster was just completed yesterday (see that THREAD HERE). Water was done filling a couple hours ago and after a lot of scratching my head I finally got the pump primed. My plaster guy told me to run suction from main drain only until plaster dust is gone. So I closed the gate on my float valve all the way and put it back in the bottom of the skimmer, but there still seems to be A LOT of movement in the skimmer, and I can't tell if it's pulling from the main drain at all. Obviously I've never tried to use the main drain before.
So my question is...should there be some movement in the skimmer with the float diverter closed all the way or should it be completely still in there?
Thanks in advance!
Thanks in advance!
