I have an inground pool with vinyl liner. Pool slowly leaks water down to a point just below the skimmer. Would this most likely indicate that the leak is located somewhere in or around the skimmer? I have put putty in pretty much every place around skimmer that i thought the leak may be. Even if i had a new liner installed, wouldn't the leak still continue if the problem is within the skimmer? Just not sure where to go from here. I just pray that there is not a lot of damage underneath my liner. Thanks guys.
