Let me start off by saying I'm still fairly new to pool maintenance. This is our first home with a pool, and while we lived here about 6 months now, I still feel like I have a lot to learn.
I've noticed that the skimmer basket no longer catches much debris. After a windy day (or any day really), I come home from work to a pool littered with floating leaves and other junk, and the top of the water just looks kind of dirty in general. I find myself spending a lot of time skimming manually. The basket does not really seem to catch much debris these days. Here is a summary of the type of pool and equipment:
I noticed there are two openings at the bottom of the skimmer (Skimmer bottom.jpg), with what I believe is referred to as a diverter flap. Best I can tell, one opening is a line to the two drains at the bottom of the pool and the other is the suction line back to the pump. Only one of the holes seem to have suction on it anyway. The screw holding the flap was also fairly loose so the flap kind of moved around when the pump was off and I would take the basket in/out, etc.
Here is what I've checked or tried so far, and other relevant information:
My suspicion at this point, is that maybe there are some leaves/gunk in the suction line from the skimmer to the pump. The skimmer basket and the pump strainer basket seem okay, and are not damaged in any way so I don't think anything large could have made it's way in. Also, a few months ago I installed a leaf trap inline on the hose that connects the suction cleaner to the side wall port. Prior to that, anything it sucked up would have gone straight to the pump strainer basket.
I guess at this point, my questions are as follows:
I was considering purchasing a drain cleaning bladder and starting to try flushing the suction line at the skimmer hole and also by taking apart the 3-way valve there. In addition, I was going to try and check the pump impeller for debris/clogs. I'm definitely open to other suggestions so please let me know if you have any thoughts or recommendations.
Sorry for the long-winded thread; just wanted to try and explain everything in detail and try to find the best solution.
Thanks in advance for any insight!
- IG concrete pool with aquabright eco finish
- 1.5 HP single speed pump
- Hayward C3025 cartridge filter
- Suction side cleaner/vacuum (connected via side port in pool wall) which I normally leave in the pool 24x7 (except if the pool is being used)
- Cleaner suction seems strong and the cleaner is able to walk up the walls, keeps bottom of pool clean, etc.
- There is a 3-way diverter valve on the suction side labeled Main Drain and Cleaner ( MD+Vacuum.jpg)
- The Cleaner side seems to be for the side wall port only (best I can tell)
- The Main Drain side seems to be for the skimmer (best I can tell)
- There is a 3-way diverter on the return side which serves the eyelets and the waterfall.
- I normally keep the waterfall shut off using the 3-way diverter valve (Return+Waterfall.jpg)
- Filter cartridges were thoroughly cleaned last month and the pressure looks normal.
- We have 3 return eyelets and they all seem to have great pressure. They are pointed down toward the bottom of the pool (per the user guide for the Hayward Aquanaut 200 suction cleaner).
- Tried shutting off the side vacuum port that the cleaner is connected to but it didn't seem to increase suction on the port in the bottom of the skimmer.
- Side note - if I start to close off the Main Drain valve the pump starts to lose its prime. I'm guessing that means the cleaner can't consume enough water to satisfy the pump? I normally keep this valve sitting right in the middle.
- I tried sliding the diverter flap to cover the drain hole (non-suction); didn't really seem to make a difference.
- Tried partially covering the suction hole to try and increase the pull toward the skimmer but it didn't seem like it really changed much
- What do you think might be the culprit for poor skimming here?
- Should that flap stay completely open and not cover either hole during normal operation, or should it be adjusted somehow? Does the screw need to be tightened so that it stays in place where I put it, or does the flap need to move freely?
