Sure, first Zeo has to be fully washed before use, either by the hose method or Backwash if you have a MPV. After zeo is cleaned then you can use it on filtering mode but you mainly need a VS pump because, Zeo likes low and slow. If you ever exceed flow rate more than 15-18GPM it will not filter. Backwash and Rinse has to be done at 26-31GPM. You cant backwash often, i do it every 8-12 months. If you ever forget to put the MPV on recirculate when using your water features at higher GPM you will flush all the dirt back into the pool, which is very frustrating as it takes a full week for the zeo to clean it back up at low and slow GPM.
