Hello hello,
I just bought a house with a pool in New England and we added a Sta-Rite propane heater to our existing Hayward super pump and sand filter. We also just bought a dolphin active 30.
From what I've read there are a few considerations:
What I've seen: I've seen some cheap ~$50 wifi timers it seems like that could work for the pump and I could find something similar for the heater and setup a routine to handle the timing delay, but I'm not sure.
I can probably justify spending ~$500, but most of the pool automation systems seem to be between 1k - 4k and have a bunch of features I don't care about (and never will) like light control, water feature control, hot tub control, valve actuators, etc. Philips hue owns my soul and I don't have any of the other features, just a pool, so it seems like overkill.
Thanks in advance for any information/guidance
- I need to turn off the heater ~15 minutes before the pump
- I need to run the pump for ~8 hr/day.
- I need the pump running while the vacuum is running
- Run the pump daily on a schedule without going out to the pool shed
- Schedule the dolphin to run periodically while the pump is already running
- Run the dolphin and pump ad-hoc from my phone
- Turn on the heater/pump from my phone
- Heater temperature control from phone
- Voice control and/or ability to integrate with home assistant
Software: I'm experienced with the home automation side of things and generally if I have on/off for each of the devices I can configure something (custom code or IFTTT) to setup the routines or triggers I'm looking for.
Hardware: I've tinkered with raspberry pi and stuff like that, but something about the risk of burning out control boards on thousands of dollars of equipment scares me
