Silly question - Just open it up?
synapsid
58
Long Island, NY
Hi Friends,
My AGP is still standing after its first winter. I'm getting ready to open it either this weekend or next. I am assuming the first steps are:
1. Drain water off the top of the cover
2. Untie and roll back the cover to remove it
3. Hook up plumbing
4. Fill
5. Run it for 24 hours
6. Check chemicals and start balancing them
Is that correct? First time reopener so I appreciate any words of advice.
Thanks!
That's basically it. Here's our article.
Reactions: synapsid
Weekends have been slow lately so it's likely you'll have several regulars sitting around waiting for the next post to come in if you hit any snags.
Reactions: synapsid
So after filling with hose water I tested and found
FC=8 (this surprised me, I checked again and got the same)
CC=0
CYA <30
Unfortunately when I opened the valves on the plumbing, I discovered a crack in some part of the heat pump. Water gushes out just from gravity. So, waiting for a service call until I can be up and running :brickwall:
Reactions: newdude
Use a submersible pump to circulate the water. You can get the CYA to 30 and dose daily FC. It won't be polished with the filter offline, but it won't be a swamp either.
I'll take slightly dirty but sterile water, Any. Day. Of. The. Week.
Reactions: synapsid
Ok! Heat pump was an easy fix, got the water circulating now. Only cost me a week 🫤
Readings are now
FC 2
CC 0
CYA below 30
TA 12
pH 7
Salt 2400
Any particular order i should start adding stuff?
Also— pool math tells me to boost the PH with 5 pounds of baking soda and the TA with 8 oz of soda ash. But wouldn’t the baking soda alone raise the TA?
Thanks
Baking soda is for TA
Borax is for PH.
You made a typo with 12 TA. What was it ?
CYA to 30
FC to 8
TA to 60 or 70.
Salt to 3200
Ph is fine at 7 and will rise on its own.
OK We're getting there! I started up the SWCG, that thing is a beast. It brought FC up to 14. I shut it off for now but I'm thinking I need to dial in a much smaller time to have it on, maybe just an hour or two a day?
This morning i'm reading:
FC 14
CC 0
TA 60
CYA 30
Salt 3000
I'm assuming this is safe to swim in, but could use a few tweaks. Should the CYA go higher?
Use pool math effects of adding (upper left menu).
Select SWG, then your unit, then you can mess with hours and % of those hours that it produces. For example, 50% of 6 hours is really 100% for 3 hours, spread out.
But yeah. Mess around and see what small tweaks will do to production.
I'm in full sun and was seeing 4 to 6ppm loss a few weeks ago, which was crazy high for the early season for us. I'm already at 60 or 70 CYA. When you notice a loss above 4, or really that you're producing 4+ a day and the FC is holding, then you'll need to raise your CYA also.
******No raising CYA without an Overnight Chlorine Loss Test.*******
1) the FC loss may be algae and not UV
2) every 10 CYA raises SLAM +4 FC and it gets expensive quick.
Reactions: synapsid
Related question, does a solar (bubble wrap type) cover affect the overnight test? I've been leaving it on to keep the heat in but I can leave it off if it will get a more accurate overnight loss reading
Sorry I did not reply with results! Too busy swimming 😁
The OCLT showed zero chlorine loss. Since then i didn’t tweak anything really.
I cranked back the SWG to only a few hours, but forgot to put it on auto. So it was continuing to outpace FC loss and im sitting at FC=15.5
CC=0.5
CYA 30
TA 50
pH 7.4
Salt 3000
I’m going to leave the SWG off for today and maybe add some more baking soda for the alkalinity. Anything else i should do with these results?
Thanks!
So you have enough FC for today ?
GREAT. (y)
Consider raising the CYA for any nice weekend days that you go uncovered all day. You effectively have two pools (covered / uncovered) and need to be prepared for the higher loss situation when it happens. Or forsee it happening and add enough FC to make it through the swim day.
I would. +10 won't hurt but it will give you some wiggle room if we get any wet spells.
You're sitting pretty. If you don't raise the CYA (always need a current OCLT before adding if more than +10), be on the lookout for it to drop from rain. Most of us only realize it when we see the FC tank. Lol.
Reactions: synapsid
