Silencer Air Blower Question
dmh
67
Houston, TX
10K gallon pool with attached spa. All Pentair equipment.
I am having an issue with my Silencer Air Blower (1.5 hp), as follows:
1. Turn on spa. Works perfectly.
2. Turn on air blower. Works perfectly.
3. Turn OFF air blower. Bubbles continue at about 20% the usual rate even the blower is off.
4. Turn off spa (switch to pool). Bubbles stop.
5. Turn spa back on. No bubbles until I turn on the blower again.
There is no air in the pool pump.
It seems like an air leak from the Air Blower when it is turn off. Is there a check valve in that line? Perhaps it is not closing completely until the spa is switched over to the pool? I am having trouble finding an exploded parts view for the Air Blower to see what is in the Air Blower housing.
No check valve often in air line and no need for it. I think you are seeing a venturi effect with your water flow pulling air in from the air line even when the blower is off. Is it really a problem for you?
Only in that I have had the same pool equipment for about 8 years and never saw this before. The "after-the-fact" bubbles just started in the last week or two. I haven't done any major repairs to the pool equipment for at least a year or two, so that is not the answer. Has anyone else seen this happen?
