I have installed the Raypak 106a for a 5000 gallon above ground and loving it. I had a question about usage with the pool pump and wondering about shut off procedure.
Is it OK to allow the heater to turn off triggered by the pump stopping it's run time? Or should I install a timer or manually turn it off prior to the pump shutting off? It's a pain to turn it off manually but I don't want to risk damaging it if having the pump control is via the pressure valve is dangerous or can damage the heater.
