That is absolutely bogus advice. The only person benefitting from this is your pool guy, because he can sell you all the chemicals to rebalance your your water after the drain and refill. And next year again. And again. And again...
And that number of 205ppm doesn't make sense at all. Just having standard levels of TA, CYA and CH would lead to a higher TDS than just 205ppm. Maybe he is referring to salt and not TDS, or the increase from last year. Or just testing wrong, if at all.
But also salt at 205ppm is no problem at all. My pool runs at 4500ppm salt (that's what my Aussie SWG wants), and I have no issues whatsoever maintaining correct pH and chlorine.
All chlorine pools built up salt over time, and to much higher levels than just 205ppm. That's normal and nothing to worry about.
But as Marty suggested. Run a full set of tests and post the results.
