Hello all.
Just joined and found the site by searching for info about my Pools Valves and trying to figure out whether I had Positive, or Non-Positive seals. I have Positive.
Now, my searching around the net, since none of the local suppliers have parts, only complete valves, I've discovered I could either buy the Diverter valve part for about $35, or I could buy the entire Jandy Space Saver Valves for about $45. Mine are the older Grey 3 point units and they're about 20, or so years old and I didn't know that I was supposed to lube them periodically so the rubber seal on them are shot and don't really seal very well.
I've also noticed the Black, Never-Lube valves are about the same price.
So, I'm wondering if I wouldn't be better off replacing the older units with the newer Never-Lube units since it costs nearly as much as it would cost to just replace the internals of the original units.
Are there any significant advantages to the Never-Lube over the Space Saver units?
Here's a shot of my setup to give you an idea. I'm handy and not afraid of cutting and refitting pipe. Over the years, I have quite a collection of pipe and fittings in the garage.
Thanks all in advance for your input and advice. I appreciate all that I get.
John
John
