Should I Adjust TA?
ASchmidt
13
Tampa
Hello, we are in the 28 day start up with Pebble Tech and I am attempting to follow their recommended levels for this first month so I’m ignoring the pool math recommended levels for now. Our PH is, as expected, going high. These test results are after I over corrected last night but I anticipate it to be back or above the recommended level today. I am adjusting with acid and then will play with timing of water features after pool school tomorrow.
Is it worth it to try and bump up the TA to the recommended minimum of 80 while I’m struggling to keep the PH down? I added chlorine this morning so that should be back in normal range today but I think I’ll also be adding a lot of that until our SWG is turned on.
