First last year my booster pump inside caseingg froze and caused casing to crack and we had to replace it. That was the second winter we had the pool. The pool had been on freeze protection and we were not aware of the crack until the booster pump was turned on. I did not know the booster pump which runs the cleaner needed to be turned on during freez protection but what is have read in this forum it needs a I run during freeze protection. But now that it have the booster pump on the spa will be drained after running the freeze protection cycle for 8 hours . This is what I Read happens when booster pump comes on during freeze protection. 1) is that true and if not then what is causing me to loose water in the spa in freeze protection mode .? I have not had that happen before. 2) do I leave booster pump off in freeze mode and use just let the pool pump run during the freeze time and wrapp the booster pump off o protect it from the freeze in hopes the freeze will not damage it again? Thx
