- Jun 7, 2022
- 34
- Vinyl
- Intex Krystal Clear
I have the dust like substance on the bottom of my pool. When I first noticed it I thought it was algae and tested my FC and CC and it was fine (3.5/0). Figured out it was like sediment (I do not know what else to call it).
Pool had not been used for 4 or 5 days and all this had just settled to the bottom. So I got the vacuum out and it comes off very easy..but then noticed the filter was not filtering it out - just recirculating back into pool. I did a back wash and flush still same result. (I am on correct setting for filter - I double checked). I did take valve off filter and sand must have settled since now it is below the minimum mark.
So my plan is to dump old sand and refill to max mark. But is there anything else I should be doing to help catch all the very fine dust (or whatever you want to call it)? You do not even have to brush it off - just fan the area with your foot and it comes off surface. If I remember correctly "clarifiers" are not good?
Pool has been super clean up until a week ago. Water extremely clear.
Thanks!
Thanks!
