Shotcrete quality question
gary65536
9
Irvine, CA
Shotcrete for a new pool build was completed a few days ago. I'm owner builder. I noticed that there are around 20 voids in the concrete ranging from 1" to 3" deep. I also noticed quite a bit of what looks like honeycombing. Is this expected quality for shotcrete? If not, should I expect the shotcrete company to address this?
Voids are common in Shotcrete and Gunite, the depths are what you need to be concerned about. At a 3” depth you could possibly be getting close to the steel cage and run the risk of water rusting the steel and making its way to the surface and staining the plaster. Hydraulic cement is used to fill the voids prior to the application of plaster. On a side note, are you keeping the shell continuously hydrated?
