what do you mean by plans? I did have the rebar inspection and passed. then there will be another one for the grounding of the pool after the grounding and tile, whatever that means... do you recommend getting an inspection from a different company?Do you have plans for this pool or are you in an area that has no inspections? The roughness isnt ideal but I've seen worst. The bond beam thickness is very narrow in those pics, that isnt normal should be 8" minimum generally often 10 to 12"
