- Aug 20, 2020
- 7,811
- Plaster
- CircuPool RJ-60
Yes, but you said the following earlier so I wanted to make sure it was understood. When you are performing a SLAM, it’s 12. Normally should be 4-6.With a 30 cya level it says 4-6 fc is ideal correct? Today I just tested and it was 5.5 with a cc of less than .5. 12 is what you keep it at when slamming correct? At least that's what I understood it as. This is my first year of doing the SLAM way. I was a new pool owner when I first joined and all that talk was very overwhelming so the past 2 summers I did it the shock every week or two and used the phos free.
My cya levels are 30 and the recommended chlorine level is 4-6 with SLAM.
