Mine only uses 1-3 as the rec when its 0 CYA above it.
OK, I found what you are talking about above. When I would select FC, it would automatically scroll down to current FC and desired FC. I never saw the CYA entry because you have to scroll back up to see it (at least on mine)
So, I entered 40 as CYA and now it shows a recommended range of 4-7ppm. For a couple of months now I was setting at about 3ppm and sometimes it would get near 1ppm by the next day.
As for my question about what I was calling shocking, it was based on my recollection of the builder saying about once per month I would need to pour a gal or two of liquid chlorine into the pool. Not something I saw here. And one reason I began to wonder if I needed to shock(may not be the correct term) the pool, is because it seems like the FC is dropping faster than it was before but then again, more sun and heat.
I checked the combined chlorine this evening and if I did it correctly, it was showing zero. Is that possible? Because the FC is at 3.6ppm. Wouldn't combined be at least as high as the FC?
Either way, I will try to make sure the FC does not drop below 3ppm. It may be some time before the system will be put on salt.
Most pools lose up to 3 ppm of FC per day to burn off, bather load, etc
We have not had a lot of people here as of yet but the FC is dropping more rapidly than it was earlier in the season. I would say about 2 ppm drop/day is what we are seeing.
By any chance are you clicking the “Check Mark” and entering your current test results?
I wasn't but have now. Thanks.
Just remember to input your pool volume at the top, then go to the bottom and pick that you want to follow the TFP recommenation levels and your pool and sanitizer options.
I had the info populated, set for recommendations but I missed the CYA field on the FC section. It looks like it's inline now with what everyone is saying.
Thanks for the input!
