duraleigh said:Doug,
1. Your pump should run 24/7 until your pool is clear....the thread has gotten confusing but I don't think your pool is clear.
2. You can only perform the overnight FC loss test if you turn OFF the SWG....Read how in pool school.
3. Because you are (I think) still experienceing an overnight FC loss of more than .5ppm, you have not finished shocking your pool.
Run your FC to 30 (Your CYA is still 80, right?) hold your FC at 30 until the pool is crystal clear, run your pump 24/7, backwash/clean your filter as needed.
Shocking and getting your pool crystal clear is all about killing and cleaning.....killing all theorganics in your pool (not done yet) and then cleaning up and filtering out the "carcasses".
1. Sorry the thread has gotten confusing. I apologize. I DID run the pump 24/7 while I was shocking. i did not turn my pump off until I had 0 FC loss overnight. At that point I turned the system back on auto and ran it for 8 hours/day. My reference to 8 hours was previous to algae and what I had set the timer for on a normal run day.
2. I understand that a chlorine drop test must have the SWG off. I have been completing my tests just this way.
3. I agree with you. I have already begun shocking again.
What you just described by holding FC at 30 and killing and cleaning, etc is exactly what I did the first time around. It's got to be close because the pool is still clear today. Hopefully this won't take too long.
Doug
