I have a large shallow area with 3 channels that go to a huge landing. All are about 4" to 6" in depth. I want to clean it with a 25 micron bag. I can clean larger debris with a net. I've called, asked, but no one seems to have a good solution for under $500, or even $1000. Below are some things I have tried and researched:
1. Call Bottom Feeder. Great vacuum for 4" area. However, they don't make heads that is about 8" wide to clean my 12" and 24" wide channels. It's also about $1500 with the smallest micron bag of 57 or attach a 60 sf filter.
2. Someone suggest to brush and push it to the main pool area and let riptide do the job. Lot of labor to brush and pushing it out one channel sucks in the other channel. A lot of work for little result.
3. Riptide or hammerhead requires at least 12" depth.
4. I used a pondovac or similar. Hoses, electrical cables, tubes, weak suction, and stops every 30 seconds is time consuming and too may parts to setup and carry. The other end drains out into a 25 micron bag.
5. Pool side/skimmer suction hose. Hoses requiring water filled to work, and it would just suck it right into my filter. Don't want that either.
6. Pool Blaster: Portable, but requires 12" depth. No go.
7. I looked and tried the Kokido xtrovac 200. It's tiny and was similar to using a handheld vacuum on a whole primary bedroom floor. They have the kokido 410 which looks promising, but I don't know if it will do 4" shallow area. Also, the smallest micron bag is 250 microns.
If I may ask you to put on your engineering cap, please make suggestions on what is the most efficient, cost effective way get the best and quickest result in cleaning the shallow area. I want something portable with a re-sizeable head to do 18" or 8" wide. I want something powerful like the bottom feeder (I think around 18 gallons/minute) and do small debris that could be heavy like a small pebble) and run off a 12v lifepo4 battery like the riptide. I want something that can connect to standard pool pole. I'll provide the manual labor as long as it provide quick results.
For reference, the tile is 16x16. The length of the steps is almost 40 ft long.
