The only place I had to mount my CircuPool controller box was a south-facing wall that is in direct sun for 6+ hours every day. I knew the plastic wasn't going to fare well, so I wanted to shade it somehow. After thinking about it for far too long I came upon the idea of a lightweight box that would attach to the controller box itself, much the same way the controller box itself mounts to the wall bracket.
This is what I came up with. It's not a masterpiece, but it gets the job done and isn't a total eyesore, just somewhat of an eyesore. The back and bottom are open for air flow with a 3/4-inch gap between the mounting wall surface and the box on the sides, and there is ventilation between the "roof" and the sides.
The first picture is just to illustrate how it mounts to the controller box.
The finished product.
Google Sketchup plans for the frame are attached. I just used 1/4 exterior sanded plywood for the shell and painted everything white to reflect as much heat as possible.
