Several problems in my equipment area. What should I replace? What should I leave alone?
jfreeman
62
Houston, TX
CircuPool RJ-45 Plus
Pool is 30 years old. Several problems have reached a head recently that make me want to rebuild a big portion of the plumbing in the equipment area. Pictures are in this album. I'm numbering the problems in case you want to refer to them in your replies.
  1. I replaced the filter pump lid a few weeks ago, and it is now in a position that I cannot loosen it. For the entire time I've owned it, it has lied between the salt cell and the filter without enough clearance for the lid tool to swing around. I want to move the salt cell further back, next to the filter pump motor, to give the lid room.
  2. I don't use the booster pump any more. I want to remove it and the pipes connected to it, but leave the vertical sections that enter the ground (capped off) in case someone (me or a future owner) wants to bring it back later.
  3. The tablet chlorine feeder (Pentair Rainbow 320) is after the return valve, meaning it does not work if water is returned to the spa only. I recently resurfaced the pool, and the builder suggested I replace the feeder because it is old. Do I need to replace it, or can it be repaired? I want to move it before the return valve. Will I need to install a check valve, or is the one inside sufficient?
  4. The Hayward Vari-Flo multi-port valve has become very hard to turn. How long do these things last? Do I need to clean or lubricate it? Should I replace it?
  5. There is a pinhole leak immediately after the MPV port heading to the heater. Can it be sealed without cutting the pipe?
  6. The Jandy "NeverLube" suction and return valves are old, but I think they work quite well. How long are they supposed to last? Can I leave them alone?
  7. There's a strange gray fitting on one of the pool return lines. It is lableled "Ortega // Purex Pool Equipment", and Google suggests it is a check valve. Why is it there? Why isn't it placed before both pool return lines?
Post a few pics of your equipment pad from a few different angles to give us a better idea of your setup.
