I just picked up this old hot tub. Filled it up, ran a cleaning cycle and set the temperature to 104, then 85.
When I set the temperature the read out will display as expected, then goes blank after ~ 30 seconds. I don't think this is expected behavior - I'm expecting the display to read the set temperature, then display whatever the actual temperature of the tub is.
More importantly, I don't think the tub is actually heating. I took a look at the control panel and the heater light will come on when the jets are low, but not in any other scenario. Even when the light is on I don't think this is actually heating.
That'd be great if I'm misunderstanding the process and it's working as expected. But I've had it plugged in about 2 hours now with the cover on - temperature feels the same
Here are relevant pics:
All scenarios
Green "LIM OK" light on
Set temp displays then screen goes blank
Jets off
"HTR ON" light is off.
Jets low
"D17" light is on
"HTR ON" light is on (still no temp read out)
Jets high
"D17" light is on
All scenarios
Jets off
Jets low
"D17" light is on
Jets high
"D17" light is on
