- Jun 13, 2024
- 5
- Plaster
- Jandy Truclear / Ei
This is our first summer with new pebble pool. Water is perfectly clear and no issues. My question is, we run the pool pump 24/7 and the Jandy try clear SWG also runs 24/7 at 70%. The FC stays 4.2. We use the pool every day with about 3-4 swimmers at a time. fC never drops below 3. Question is, is it bad to keep running the SWG this much or should I put it in standby mode for a few hours a day. I read that running the SWG too much can shorten its life and raise PH which is a daily occurrence. It rises from 7.6 to 8 each night. However I realize the new pebble finish is only 2 months old. I have been trying to balance manufacturers recommended levels and TFP recommendations as best I can but they don’t always agree (example TA and calcium level).
FC 4
PH 7.6
TA 100
CA 260
Salt 3000
CYA 30
CSI -0.10
FC 4
PH 7.6
TA 100
CA 260
Salt 3000
CYA 30
CSI -0.10
